Rod (or anyone else) here is a link to the main post.
http://www.yamahaoutboardparts.com/f...k-th28818.html
It has gotten long so here is the latest.
You had me test loaded and unloaded and below are the readings. Loaded it appears I need to replace the charge coil, but unloaded it says I need to replace the CDI. What would make the charge coil be under spec only when loaded?
Everything connected. I assume this is "connect" in the manual.
CDI to coil - 0V, spec is 130V
Charge coil - 35V between R-BR, 6V and dropping between R-Blue, spec is 60V and 100V.
Pulser coil - 10V, spec is 5V
Disconnected. I assume this is "open" in the manual.
CDI to coil - climbs to 105V over 6-8 seconds where I stop, spec isn't listed, just "---".
Charge coil - 90V between R-BR, 125V between R-Blue, spec is 55V and 90V
Pulser coil - 11V, spec is 7V.
Thank you, others, and 99yam40 for all the help!
