Boscoe read the idle speed adjustment procedure carefully.
how can you take loose the top and middle carbs linkages and then adjust the idle speed on a running motor before closing off the throttle plates and syncing all 3 carbs together?
it reads just like my manual, but it has to be wrong sequence in steps.
OP has not said what his idle or WOT timing is when pointer is on the lines/marks, but mine was about 14 deg ATDC at idle when it should have been 7 Deg. the idle speed adjustment had to be adjusted more to get the proper idle speed and it did not idle well retarded that far.
OP if I remember correctly there is some fluctuation showing up with the light, not steady on the mark
