Hello. I'm putting the camshafts on both heads back in and I would like to know how to line them up or if anyone has a diagram they would share. Thank You, Brian
2003 Yamaha 225 4 stroke (re installing camshafts)
you will find detailed instructions in the Yamaha service manual.
done many of them but I don't have the manual in front of me here at home.
it covers setting up the crank, lining up both banks cams and cam drive chains and sprockets/.
luckily this is a clearance motor.
screw it up and it means you get to try again.
most other 4 strokes if you screw it up it bends valves and rods.
Originally posted by rodbolt17 View Postyou will find detailed instructions in the Yamaha service manual.
Yamaha tells the mechanics that breaking cam shafts or breaking cam shaft belt tensioners is not covered by any warranty. I suspect the mechanics tell the customers that it was time for new parts anyhow.
ÂÂÂÂ
