Question on the 5v reference sent to sensors and if a reading of 4.97-4.98v at key on engine off is good or should I be looking for a short?
This is on a 2004 F115TLRC. The Intake pressure sensor and the Throttle position sensor are the only two that have the 5v reference wire from the ECM.
I know Rodbolt has referenced the voltage check many times but I was unsure if the above values were okay?
