F15 Warning Lights
    Well I found a few things:
    - The LED for the overheat is burnt out. The oil pressure LED tests OK.
    - I did not get an Alarm for the orginal over temp because there is no buzzer on this engine, it's a option not installed.
    - The over temp switch when grounded out works fine...engine goes into reduced RPM.
    - The oil pressure switch when grounded turns on the red LED and engine goes into reduced RPM mode..like it should.
    I found a bit of what appears to be a bit of the old impeller in the fuel pump body obstructing the flow somewhat to the pee hole on the cowl. Peeing better now.
    Thanks for the help.
