On my F115TLRC the battery voltage periodically drops to about 11.5 volts according to the diagnostic readout I obtained the other day. I think this has maybe been two or three times that I know of, but the readout I got
Thursday only showed one time at 172 hours on the ECM, yes the 2004 motor only shows 178 hours, but I don't have anyway to know if the ECM was ever replaced before I bought the boat. I have noticed the Volt gauge every once in awhile will show charging below 12v. Usually after motor is stopped and restarted to move the boat it has always charged at normal rate around 14v. In the service repair manual it talks about a 6 pin harness needed to check the lighting coil and or rectifier? On one of these threads I thought it was talking about just checking the wires with just a volt/ohm meter? Is this possible without buying the $100 six pin harness and how is it done? The diagnostic readout attached was done as a stationary test not and active one. This was my first attempt with the software and was just looking at what was going to show up.
Boscoe or Rodbolt your very detailed knowledge is much appreciated!!!
