1995 150 TRXT
The boat ran good last year. It is run in salt water but I flush religiously after each use. I went to start it for the season and when I went to start it off the muffs I didn't get any stream. I pushed the muffs together and got a weak stream. Then my over heat alarm went off. I just did the water pump and got the same result. I ran the motor in a barrel and got the same result. If I connect the flush to the hose I get a good stream but did not run the engine. Any ideas what this could be and is it okay to run the motor in a barrel and off the flush. I think that would help pin point the problem. Thermostats were done last year. I cold do them again but I really don't think it's my issue.
Thanks!
Thanks!
