Hi, I've got a few questions regarding the associated wiring on my '03 75HP 4-stroke. If this post seems a bit long-winded or too noob-ish I apologize up front.
The motor is mounted on a Sylvan along with a model 703 remote control, with power tilt/trim and choke lever. The boat currently only has a speedometer w/pitot tube and fuel gauge, and the connections between the gauges and the remote control is via a harness with a Smokercraft (Sylvan -> division of Smokercraft) part #.
I want to add at the least a tach and a trim/tilt gauge, so I'm trying to decipher the existing wiring. I'm not compelled to replace the 2 guages there already but I'm not against doing so either.
Coming out of the 703 control there are 3 cables with bullet connectors. The first cable has the red, black (ground), yellow (switched power) and dark green wire. I assume this dark green wire is for the tach? I'm assuming the red is unswitched power but haven't confirmed it.
The other 2 cables each have a red, light green, and light blue (purple?) cable, and 2 cables of each color are spliced together, so there are 3 more free bullet connectors. What is the purpose of each these wires?
Also, looking at the starboard side of the engine a few inches from the fuses, there are 2 connectors that I'm trying to identify.
The first one is a 4-pin female connector with 2 wires; 1 dark pink w/black stripe, the other ligher pink w/white stripe. It appears that light pink wire runs to, or near, the oil pressure switch on the upper port side and the darker pink wire runs to or near the TPS on the lower port side.
The 2nd connector is a male connector with a black and a pink wire and also a grey wire which is approx. 2" long with its other end terminated by a bullet connector. The black and pink wires run into a plastic jacket which itself appears to run to, or at least near, the PTT unit mounted at the front of the motor's mounting assembly.
What is the function of these 2 connectors, and will I need some kind of standard auxilliary harness that connects to them and which runs to the 703 and/or the gauges directly?
I haven't decided on exactly which gauge type I'm going to use so I can be flexible if needed, if there's a recommendation of a particular type/style I'd like to hear it as well.
I do have the recommended (F100X) service manual, but if the info I'm looking for is in there I've completely missed it.
Thanks for any help.
-- Larry
-- Larry
