F225txrd - no power, shaking - diagnosed!
  • F225txrd - no power, shaking - diagnosed!
    So traveled about 35 miles today - motor running fine with 1725 hours on it
    BUT - the last 1/2 mile - coming up my canal - something happened!
    power dropped WAY off - the whole motor SHOOK and SHUDDERED
    I had to advance the throttle just to keep moving -
    what could have happened?
    multiple cylinders misfiring?
    maybe the gears in the lower unit seizing?
    I could barely maneuver the boat to the dock to shut it down!
    then, at the dock, I tilted it up
      Rotational smegma. Classic.
        Did that leak out of your LU??
          What would drano do to that weed?
            Bet it'd clean all the carbon off it!!
            Just re-plant and re-use!
              must have been a pissed off manetee shoved that into you prop
                Needs to quit babying that engine so much. Run it up to 6000 and blow that thing right off.
