Yamaha 115 water pump kit ?
  • Yamaha 115 water pump kit ?
    I have a 115TJR / 2008. Jet drive
    The water pump kit I got , from a Yamaha dealer
    68V-W0078-00
    didn't fit
    PN I think I need is 68V-W0078-00-00
    But
    when I look it up on line is see differences in the individual part numbers in the kit & the insert cartridge is different.
    Mine has two ears sticking up 180° apart to lock the cartridge into the water pump housing
    but the housing in the kit I got has the ears 90° apart, the impeller key is too big, (don't fit into the slot in the drive shaft) & the impeller is a tad smaller.
    When I look up the 00-00 number, I see 2 different insert cartridges, one with the ears 90° apart & some have the ears 180° apart.
    How do I get the right one
    I need the one with the ears 180° apart
    This pic show it 90° apart:
    2006 and Later F115TJR-PUMP Yamaha Outboard WATER PUMP ADAPTER F115 Diagram and Parts
    My insert cartridge looks like this one with the ears 180° from each other,
    The 00-00 kit shows the cartridge with the ears 90° from each other .
      Also
      The new bolts in the kit are not long enough.
      From experience I know I need longer water pump housing bolts.
      I use the original bolts that are longer.
      Running is in muddy/silty river here,
      this is my 3rd time replacing the water pump
      but the new PN / & parts now don't jive with what is on my 115/80jet 08 TJR
        68V-W0078-00 and 68V-W0078-00-00 are one and the same. The first just has the last two digits missing.
        More to follow.
          61A-44311-01-00 YAMAHA HOUSING,WATER PUMP
          6E5-44322-00-00 YAMAHA INSERT CARTRIDGE
            Checking it out
            Last time I replaced it looked real bad.
            Just want to avoid this
            http://www.yamahaoutboardparts.com/87348-post3.html
              So there's no OEM "water pump kit" for my motor ?
              just need to use the original longer bolts
              & I have to buy the the individual parts
              I have to buy individually parts 11 thru 16 ?
              Might not hurt to get a new housing too, 10 thru 16,
                The PN you referenced :
                (doesn't show it to be used on the TJR-P "Water pump Adapter 115 " ?
                it's different than the one for the TJR-P
                "water pump adapter 115":
                6E5-44311-00-00 YAMAHA HOUSING,WATER PUMP
                But the
                is the same
                2005 F115TJRD-P Yamaha Outboard WATER PUMP ADAPTER F115 Diagram and Parts
                Not trying to be difficult,
                But Iv'e just replaced the drive shaft assembly
                Had it all apart, & is back together.
                Had the wrong water pump parts
                (Used the old water pump parts, look OK,( slight wear) but want to have the new parts on hand )
                Waiting for "liquid water" so I can test run it.
                The next time I pull it apart, having the right part is a lot more fun.
                  jet drives must be looked up as jet drives.
                  or the parts may be wrong.
                    Yea
                    Learning that
                    Mallory makes a water pump kit that looks correct
                    Used one years ago, fit all but impeller key & bolts
                    Like using OEM , it was the only one in my area , on hand
                    Will research jet drive sites
                    A common maintenance part here & lots of 115 Yamaha jets
                    A water pump kit should be an off the shelf item
                    May need to go to Anchorage,
                    hate the thought LOL :-)
                      Installed water pump/pic
                      I put the old water pump back in, didn't look bad
                      Should get thru the Sumer with it.
                      Will get a spare for on the boat though.
                      No repair shops miles miles up the Yetna R. Sand bar repair only
                        From Boats net(here).
                        A chat with them (on-line) found EVERYTHING for you:
                        2006 and Later F115TJR AA-8900010 Yamaha Jet Drive WATER PUMP ADAPTER F115 Diagram and Parts
                        For other Yamaha jet drive engines:
                        2006 and Later Yamaha Jet Drive Parts
                        All year jet drives:
                          WP parts specific for your engine:
                            Local Yamaha store is ordering 4 water pump kits & says they are the ones for my jet drive.
                            Said he's ordering : 68V-W0078-00-00
                            Will wait & see , (I have doubts now)
                            but if not the right one.
                            I'll probably be making an order
                            No water pump kit available , but can order the individual parts. Items 11 - 15. ( $110 + shipping )
                            Boats are black holes to throw money into LOL
                            Thanks again
                              Originally posted by bogydave View Post
                              (Item 10 is not normally a pat of the kit)
                              Thanks again
                              You can call these folks directly (as I have before when trying to buy a kit). Extremely helpful, got exactly what I needed and a bit cheaper than the dealer...
                              Good luck..
                              Got these links saved as occasional jet drive owners show up here...
