1986 yamaha 25hp model 25sj shift issue
  • 1986 yamaha 25hp model 25sj shift issue
    There is a Cam plate (part # 664-44113-01-00) related to shifting that resides just inside the bottom cowling (stbd side). The cam plate has a pin that transfers motion from the gearcase handle to the linkage (which then transfers movement to the shift rod lever, etc). Anyway, the pin has gotten damaged and I want to replace the Cam Plate. It does not appear that there is enough room between the cowling and the block to replace the pin.
    Any suggestions on how to proceed? Is it feasible to remove just the bottom cowling? I really don't want to mess with pulling the power head....
    Thanks in advance for any suggestions.
    Regards.
    Could you post a picture so we know what exactly what you are referring to?
      The bottom cowling is bolted to the upper casing. No way to remove the cowl without removing the block.
