Hi, I've had my Yamaha 9.9 2 stroke for about 4 years, and love it dearly, but it's been slowly presenting me with different problems each year, the heathen, how dare it get old!
A crack developed at the top of the casing / shaft (apologies if I use the wrong language here - the metal bit just below the engine housing is where I mean) last year and when I got the engine serviced last year the guy said it's not too much to worry about yet, but it's grown bigger. I was planning to use some metal filler to patch it up but at the end of last year I washed out the engine at home and noticed water spitting out of the crack, which gets quite substantial as you give it throttle (see video attached).
https://youtu.be/W3yetO93bDM
A couple of questions..
Is this ok? (I feel like water should not be there to be spitting out?)
Then, would it be ok to plug it up with metal filler? (if it is ok)
Should I just take it to a pro?
Any other advice and help greatly welcomed and thanked for in advance!
