In February 2017 I replaced the low pressure fuel pumps, cleaned the O2 sensor and did some other routine maintenance on this motor. Put it back in the water and it ran great. Put it on the lift, went back about 36 hours later and it wouldn't start. Have been trying to figure this thing out since. Have had 2 different mechanics (one of which is a certified Yamaha mechanic)work on it to no avail. The 2nd mechanic got a 1,3 code with the winky-blinky tool and concluded the issue was the pulser coil. He replaced it last week (I bought it from Boats.net) but it made no difference. He subsequently determined that the fuel injectors were not firing - made some sort of a jumper wire and got the motor to at least cough - more than it's done since February. He then swapped out the resistor assembly on the injectors with an assembly off another 250 OX66 which is running. That made no difference. He concluded it had to be a problem with the CDI. Got the new CDI in today (from Boats.net), installed it and it still did not fire. What the heck is going on?!?!?!?
Any help from the Yamaha gurus here would be VERY much appreciated! For complete context here is a list of all the things that have been replaced on this motor since last October:
- Fuel line& bulb to H20/fuel separator
- H20/Fuel separator
-Onboard fuel filter
-High pressure fuel pump & regulator
-Stator
-Low pressure fuel pumps
-Plugs
-Pulser coil
-CDI
~$3500 later and I still don't have a motor that will start....and it's so weird how this cropped up just sitting on the lift.
Surely there is someone here that can figure out what the heck is going on with this motor - please help!!
Thanks for any insight into this weird problem that no one seems to be able to figure out.
Tim
-Stator
-Plugs
-Pulser coil
-CDI
Tim
