2001 200 LZ HPDI. Started losing spark intermittently. Now dead. Several mechanics failed to diagnose the problem. I have done the following: No codes have been thrown. I have swamped out the crank sensor, Pulser coil, ECU, Triggers and coils to good motor. they all ran the good motor perfectly. The good motor runs fine with the stator unplugged. I changed the ECU harness.
I have no voltage drop from the fuse blocks and have good grounds. I isolated the boat with a remote starting harness. I even cut the white kill wire. All the coils are getting 12 volts at the coils, but the ECU will not fire the coils. Something is not letting the ECU fire the coils. I need some help please.
