Thoughts on anode downstream of thermostat?
  • Thoughts on anode downstream of thermostat?
    Noticed the thermostat cover leaking on my F225TXRD some time ago, and found the "hose barb" portion to be quite corroded.
    Looking into a replacement, I learned that following the 2005 model year,
    Yamaha added tiny sacrificial anodes
    (and changed the name from cover assembly to anode assembly)
    So I've changed to the new part -both sides -
    (impressive engineering! the original part was a tight fit already - but the new larger part still squeezes in there)
    But I'm curious about Yamaha's motivation for the change.
    Was it merely to address the problem I'd just had -
    in other words, to protect only the cover itself?
    or did they think it would help prevent corrosion of the block thermostat cavity?
    which I suppose it might - but only while the engine was running with water flowing flowing through the thermostat.
    Can't imagine it could do anything while the engine is off.
    I suspect it would be for both BUT, more so for the block...
    Lots of info (bad press) on exhaust stacks, at least that's repairable.
    If your block (by the t-stats) rots out, (short of a new block or "backyardian" fix) the block is junk....
    Cheap fix to save an entire engine...(and bad press)
