I have a 2001 150 VMAX that after you run a short distance the overheat buzzer comes on and the rpms shut down to 2000 but the engine does not appear to be hot and the water coming out of pee hole is cold what could cause this
2001 vmax overheat buzzer
Have you drained it to see if the system alarms and set the indicators?
if wiring or devices go bad they can set off alarms without the proper need for then to do itLast edited by 99yam40; 03-31-2017, 09:14 AM.
Originally posted by Rohausvmax View Postthe oil pump in the remote tank is working and the oil level in the tank on the engine never gets much below full
The over temperature alarm system may be working just fine. Does not mean that there is not a fault within the over temperature warning system that is setting a false alarm.
Both systems may be hunky dory. The alarm could be completely unrelated to either the oil transfer and warning system or the over temperature warning system.
Do you have gauges?
do they tell you when an oil or over temp alarms comes in?
are they working properly?
if not fix them so you know what to chase
I pulled the water pump and checked and the stainless cup the impeller goes in was indexed 1/4 turn off. I notice this motor has a speedo hose on it, my question is since I get my speed from my gps can I eleminate this hose.
Originally posted by Rohausvmax View PostI pulled the water pump and checked and the stainless cup the impeller goes in was indexed 1/4 turn off. I notice this motor has a speedo hose on it, my question is since I get my speed from my gps can I eleminate this hose.
Never heard of the SS cup rotating... Maybe run dry and the impeller spun it..
**There are two indexing "tabs" that go into the HOUSING (to prevent rotation).
With the rotation, I would probably replace both the SS cup and housing depending on how it looks
Glad you found the issue!!!Last edited by TownsendsFJR1300; 04-07-2017, 04:30 PM.Scott
ÂÂÂÂÂÂ
