I have a new to me 02 wellcraft with an 02 F225.
I've run the boat but did not pay attention to the temp gauge nor the water psi. I was watching the digital gauges. My fault.
It has the dual round digital gauges and a analog Yamaha pro series temp gauge. It also has a water psi gauge. There are no #'s to know what the temp is.
1. what temps do the hash marks on the gauge stand for and what should it run temp wise? On the hose I noticed it creep up to half. I would expect some additional heat on the hose due to lack of water volume but I have no idea what the gauge markings mean temp wise. Also read that the temp buzzer has to be disconnected in order to run this temp gauge? Hmm.
2, the water psi did not move on the hose. Could not tell you if it did when out running on the water. I'm told these f225's are rather low psi?
I've dropped the lower and the impeller looked great.
engine pees solid at idle. no alarms. Then again, I don't have anything to judge it off.
