I have a 86 50 Yam. that the previous owner disconnected oil lines to cylinders, routed them back to oil tank and used a premix.I bought new oil line, (clear) and reconnected lines to cylinders, these lines are one piece from pump to cylinders, I know the original system has a black line, a connector, then a length of clear line, the problem is that after I,ve ran motor for even a few hours the oil will drain back down the line to the tank leaving an inch or more of empty line. I know I can't use the oil injection system like this and always premix fuel 100:1, are the check valves bad in oil pump or do I need the original oil line setup on the oil system
50 oil pump
