boat a new boat, well new to me... And well i got problems right off the bat.
It's a 1994 150hp 2-cycle.
So the issue is that when the boat warms up, about 15-20 minutes into running it, an alarm goes off under the dash and when that happens the engine will not get above 2200-2400 rpms and shakes pretty bad, it doesn't die. The first time this happened it was under load in the water, but it also would do it in neutral when i attempted to rev it up that way. It will also do it on bunny ears in the driveway too. Basically as soon as the engine is at operating temperature the alarm goes off and this happens doesn't seem to matter if its under load or not.
I have no gauges to tell me what the alarm could be... The water is spitting out of the engine in a nice steady stream, the oil reservoir on the engine is half full, the spark plugs aren't brand new but pretty damn close. When I took them all out they all appear to have the same amount of carbon build up, not too bad on all of them.
I tried removing the spark plug wires while its running, cant really tell if any of them aren't firing, i cant tell if its dropping rpms when i pull them. (is it very minor on these motors?) but it seems like they would be since when the boot is close to the plug its arching to the top of the spark plug on all the wires.
I don't know any ideas?
