Loss of hole shot.
  • Loss of hole shot.
    I have a 90 Yamaha 2 stroke. It seems that lately I have had a harder time getting on plane than normal. Almost like it doesn't have as much power as it used to. Anyone heard of this happening before.
    If you've added a bimin top or more passengers that would slow you down. Or anything that creates drag on the boat.
    Other than that I've got to first think it might be a clogged main jet since everyone here seems concerned about carb problems and just experienced one myself on 90TLR with about 20 hours.
      Bone,
      Are you still able to get as many rpms as before after you plane and trim?
      How about your spark plugs - if they are at least one year old, replace them.
      Ken K
        No added weight or passengers. I use the boat alot, and a buddy of mine that I fish with quite freguently noticed it as well. Im getting the same output @ top end. which is 5200 trimmed up. My hole shot is miserable though.
          Changed the plugs in Jan.
            if same top end then it is carb time.
              So I guess I have to bite the bullet and clean the carbs.
                sure, couple hours of time for many hours of pleasure.its always a good feeling to know youre not running your cylinders lean.
                  Bone,
                  Since your motor is running fairly well, I would try a shock treatment first before tearing down the carbs - might clean up the carbs just enough.
                  Ken K
