Will the rod eye or yoke screw off the end of the shaft ?
2004 Yamaha 40 hp trim and tilt shaft
Originally posted by boscoe99 View PostIt does make me wonder why they are not threaded on. Most of the force is pushing not pulling.
Now when it gets very slow again, perhaps I will bring up the issue that there really is no such thing as "pulling".
apparently you have already pulled the piston out of the case.
From what Rod posted , it is a matter of unscrewing the rod from the piston not the eye
Rodbolt ,Here is the picture he posted
could you give him info on unscrewing the rod without damaging the piston and rod
This looks nothing like Fairdeal's project from a few months ago. Wonder how it is taken apart?
Wonder what the exact model number might be?Last edited by pstephens46; 01-28-2017, 04:48 PM.
Fairdeal has an F225. Completely different model, with a completely different trim and tilt unit, than is the OP's model and unit.
OP's model has but one cylinder and one piston. Fairdeals has one tilt cylinder/piston and two trim cylinders/pistons.
Op's uses a piston within a piston within a cylinder.
F225 tilt piston on the left. 40 tilt/trim piston on the right.
ÂÂ
