2011 25 hp yamaha 4 stroke approx. 10 hrs on engine. Starts and idles great. Runs bad or cuts out when open throttle. Mechanic cleaned carb three times, good compression, replaced plugs,fuel filter,fuel tank,fuel line,checked timing,and replaced stator. He is out of ideas and unable to get in contact with Yamaha techs. Anyone have any ideas.
25 hp yamaha 4 stroke carb ?? problem
Originally posted by coastie88 View Post2011 25 hp yamaha 4 stroke approx. 10 hrs on engine. Starts and idles great. Runs bad or cuts out when open throttle. Mechanic cleaned carb three times, good compression, replaced plugs,fuel filter,fuel tank,fuel line,checked timing,and replaced stator. He is out of ideas and unable to get in contact with Yamaha techs. Anyone have any ideas.Jason
25hp yamaha 4 stroke
I bought boat and motor from friend. He towed boat behind his house boat. He only used house boat once a summer.Out boars is F25SEHA. When I first tried to use it started and idled fine but would cut out each time I opened throttle .After I made it back to dock( after about 10 restarts.,I tried again and was able to make about 5 full power runs.I did not want to go out for obvious reasons . I decided to take to mechanic after reading about carb problems on this engine.It has been downhill ever since.
ÂÂÂÂÂ
