Think about an updated fuel supply system for Yamaha EFI models.
One transom mounted fuel delivery module for all models.
No VST tank or inlet valve/float to deal with.
No fuel cooler needed.
No myriad number of fuel hoses on the motor.
No check valves.
No pressure relief valves.
No emissions/vapor recovery control devices.
Not much on the motor at all. Just two hoses, a pressure regulator, a lifetime filter and six injectors.
Move a few components to the boat. Like the oil tank in the boat for a two stroke model. One wire from the motor to the fuel module.
Cleaner and cooler gasoline. Easier to troubleshoot. Better power supply.
Lighter, less complex motor. Cheaper to produce. Should lower the price.
So simple. It will be huge! What is there not to like about it?
Bring it on any nattering nabobs of negativity.
No check valves.
