Did you have your balancer replaced?
If so, do you know the specific dash number balancer that was installed?
If so, can you find a single digit that is cast/stamped/embossed into your replacement balancer?
If so, does that digit correspond to the dash number of the balancer that was installed?
For instance, let's assume you have a -03-00 balancer on the motor. Do you see the number 3 somewhere on the part? If so, where? Can you snap and post a photo of the number?
