This is my neighbors boat. Long story short, this engine wont accelerate. I flushed the fuel system, checked the thermo switch, and the block temp sensor, gave it fresh fuel and when I try to accelerate, it stumbles, misses and backfires, it wont go on plane. When I back the throttle down from trying to make it go, it settles down to a pretty decent idle, after it's warm, it idles ok.
It stumbles and misses right out of the gate as well, when its not even warm, makes no difference, warm or cold.
This problem started when he towed someone out of some muck and pumped some muck through the engine. He said that the engine was still pumping fine but he replaced the pump anyway. He didn't hear any alarms.
At the time this problem started, he was running on the hull tank and has since gone to a 6 gallon above deck tank, all fuel supply/components are fresh and new.
When I started working on it, I drained a few ounces of water out of the filter bowl on the engine and cleaned everything up real well. Last time I ran it, I noticed that the bowl on the engine filter never gets completely full, its always stays a half inch below the top, is this normal?
I swear it sounds like it's starving for fuel, it pumps good out of the fuel rail (Schrader valve) but I haven't checked pressure yet.
I am starting to suspect the vct and possibly clogged injectors, a lot of work to get to it on these 150's.
Does this engine have any code that can be reset in the ecm that would send this thing into limp mode?
I'm at my wits end, Have I missed any thing simple here before I tear the fuel system down? This thing only has 100 hours on it, it's a shame to just let it sit there and rot.
Help please,
Thanks,
Help please,
Thanks,
