Lubricating Engine Mounted Studs?
  • Lubricating Engine Mounted Studs?
    Is lubricating engine mounted bolts a recommended procedure? If so, would you lightly grease the threads? Or perhaps an anti-corrosion solution? For example, the stud bolts used to secure the carb to intake.
    I'd like to do my part to prevent having to deal with a seized bolt in the future.
    Jason
    Any kind of lube is better than none. I use LPS-3 or LPS-2 on everything.
