I have a 2011 115 HP Yamaha outboard. Last time I was out on the water, the engine ran fine at first. Went 4 miles, stopped for 1 hour, started up, went 5 more miles, stopped for 1 hour and then started engine to come home. Engine would not go over 2000 RPM. If I tried to push the throttle, the engine would sputter. The fuel fill bulb was soft.
I suspect an air leak in the fuel line. At home, I removed the engine cowling and found the translucent fuel filter housing on the back of the engine. I pumped the fuel fill bulb till it was hard and the translucent fuel filter housing was completely full. Then I ran the engine at idle, Within 1 minute, I see the fuel level in the translucent filter housing drop by 3/4 of an inch. I can pump the bulb and it refills to the top. I also used the bulb to pump fuel into a glass jar; there was no water in the gas.
Does this seem like an air leak in the fuel lines before the engine? I suspect it is the fuel lines connection to the bulb. When the engine is turned (via the steering wheel). it puts a lot of stress on the lines as they connect to the bulb..
