so it is frequently mentioned,
usually in the context that "flushing" is irrelevant to the issue,
that the corrosion occurs in the "dry side" of the exhaust.
Certainly, while the engine is running,
there is no cooling water discharged onto those surfaces -
and there is presumably "exhaust pressure" present.
However - when the engine is not running,
am I wrong in thinking that "the sea" will "seek its own level" within that area?
On my F225, moored in calm water, the "water line" is just below the top bolt of the tilt/trim unit:
about the level of the bottom of the oil pan:
Now granted, there is "trapped air" present which would resist compression
But - say, at anchor, engine off, boat rising/falling in a strong swell -
is not seawater going to be forced well up into that "dry" area?
