I have 2004 200 hp hpdi..300 hours..runs perfectly for hours but when I shut the motor off and try to restart it will not start..worse is that it doesn't happen every outing 2/5 trips is the frequency..it turns over but will not fire...always starts on first try but when this happens it absolutely will not start..store it for a few days and it starts perfectly. injectors recently replaced..been to the shop twice and the problem would not duplicate
motor runs for few hours ten will not restart for several days
Originally posted by garydorman12 View PostI have 2004 200 hp hpdi..300 hours..runs perfectly for hours but when I shut the motor off and try to restart it will not start..worse is that it doesn't happen every outing 2/5 trips is the frequency..it turns over but will not fire...always starts on first try but when this happens it absolutely will not start..store it for a few days and it starts perfectly. injectors recently replaced..been to the shop twice and the problem would not duplicate
Originally posted by 99yam40 View Postwhen it will not start you will have to check to see if spark and fuel pressures are there.
Could be too much fuel(overly rich) also.
Have you tried to open the rootless some to give it more air when it will not fire up?
ÂÂÂ
