Recently purchased my first boat that has a 2001 2 stroke 150hp HPDI outboard with only 205 hours (hardly broken in). I have had the following service completed: new spark plugs, Yamaha fuel filter element, water pump kit, thermostat, fuel water separator, Yamaha zinc, high pressure fuel injection pump, fuel pump chamber gasket, fuel pump gasket, fuel pump (low pressure). For some reason my RPMs struggle. Injectors pulled cleaned and passed flow test. At Full throttle it did not exceed 1700 rpm. Any thoughts to what I am missing? Could it be a diagnostics issue with the ECU?
2001 2 Stroke 150 HP hpdi Outboard
Originally posted by 99yam40 View Postwhat was the high pressure reading at the problem RPM?Last edited by 2stroker79; 10-18-2016, 08:40 PM.
Originally posted by 2stroker79 View PostYes sir! The boat had sat for over 3 years. The pictures of old filters was a yellowish orange sludge. My dealer has done a fantastic job. Now just need hope the high pressure pump and getting the fuel injectors cleaned again is it so I can get to fishing!
