Its been a bit slow here, so I'll share some work I did some days ago.
The 2003 "F225C" Service Manual LIT-18616-02-76 has a schematic of the ECM pins by function.
Of course that was before Command Link.
My 2005 was made with the Command Link wiring harness -
and I've been fascinated by the idea that - using the same 44 pin connector -
Yamaha was able to add several more "wires":
CL data connector
CL speed sensor
CL pressure sensor
CL Trim input
So I spent some time with the continuity meter.
The 2003 schematic showed two pins as "Vacant" - and they are still not used with the Command Link harness.
To add the CL inputs/output, Yamaha re-worked the way they handled power;
"bundling" power supplied by the ECM to all the 3-wire sensors,
and changing the way power is supplied to the ECM.
The latter is the most interesting, to me - particularly what was done with the Tach output.
Below is the 2003 schematic annotated with the pin changes made for Command Link.
(I have not attempted to correct the external connections shown)
CL data connector
CL speed sensor
CL pressure sensor
CL Trim input
