1992 115TLRQ 2 cycle potential problems
  • 1992 115TLRQ 2 cycle potential problems
    Just bought a 2002 boat has a 1992 115TLRQ Yamaha outboard. Is there any common issue that I need to look out for on this model engine? It is very clean and seems to run fine. Also, what is a good source for parts for these motors?
    Thanks for any help/suggestions in advance.
    keep, oil and fuel systems clean
    it is an old motor
    hopefully it was used often as motors that sit around for too long can have problems
      Thanks,, It has the oil injection bypassed, and the powerhead does look pretty new, but not sure how to tell. compression is 110-115 on all cylinders. Are there any electronics that would be recommended to replace as a safety measure?
        Well, personally, I don't like when a motors oil injection system has been "bypassed". I would see if most of the components are still there an hook her back up, test, and adjust (you should get a Yamaha Service Manual for your Engine).
        Look at the diagram and see what you have and don't have. By the way, Boats.net is a good place for parts.
        1992 115TLRQ Yamaha Outboard OIL PUMP Diagram and Parts
        Chuck,
          The oil injection system is one of the most reliable. I would put that back in place.
          Not sure what years they changed the shift shaft but the earlier years were prone to rust.
