85 30 hp converted to tiller handle
  • 85 30 hp converted to tiller handle
    I have an 85 Yamaha 30 hp that I converted to a tiller. It has a 7 pin connector and is electric start. I need, basically, the connector and a key switch to start it, not the controls. Can someone guide me in the right direction? thanks in advance.
    Just a thought, but if you get the manual for your engine, I would think it would have a wiring diagram in there. From there, couldn't you just tap into the appropriate wires for the "run" and "start" circuits (no need for a connector or fancy wiring harnesses)? Are they red, yellow and red/purple like other manufacturers?
      Thank you for your reply. I should have added to original post that I'm a rookie doing this. Literally first time I've fooled with it. I will get a wiring diagram. Again, thanks
