2005 F150 won't immediately kill when turned off
  • 2005 F150 won't immediately kill when turned off
    My F150 won't immediately kill when I turn the ignition off. Takes about 30 seconds. Does the same thing when I pull the kill switch. Do I need to replace the ignition switch and kill switch or should I be looking for some other issue?
    perhaps apropos - July 2015:
    I have had a few F115 motors with that same failure to shut off.
    the ones with a failing ECU would drop 150-200 RPM when the key was switched off but would not shutdown or take a few minutes to shut down.
    sometimes a quick knuckle rap on the ECU would shut them off.
    my guess is you have an open circuit between engine ground and the white wire at the ECU.
    unlike most 2 stroke EFI motors the 4 stroke has to power down.
    at key off the ECU gets a shut down signal, then it has to cut off spark and fuel,reset the ISC and then shut itself down.
      http://www.yamahaoutboardparts.com/f...0-th27263.html
        F150 won't shutdown
        Thanks for the tip. I took my cable plugs apart and cleaned them with contact cleaner. Then I applied a coat of 2-26 electrical coating. Fixed the problem.
