suspicious rust on bolt
  • suspicious rust on bolt
    200 txrt
    what may be the reason for red rust appeared on head bolt?
    is it an early sign of head gasket leak?
    Thank you
    is that a crack down below the temp switch
    is any other bolt heads looking the same?
      Steel bolts. Salt water. Rust.
      That is what happens. Does not look abnormal to me.
      Scrape the rust off. Start using a corrosion prevention compound on the motor.
        should not be any salt water under cowling, newer run it without cowl.
        the only salt water is inside cooling passages.
        all Yamaha bolts, they are all stainless steel, should not be any rust.
        but again, some of my hardware (stainless steel) on deck leaking rust
        other bolts ok, no rust (see pic).
        central electrode on this spark plug looks whiter, then rest, may be exhibiting sign of lean mix or water in combustion (third plug from left, i.e. cyl #2)
        i have not used compression tester yet, but it is possible that high pressure gases in combustion chamber leak into cooling and push water past bolts?
        all this stuff works in mysterious ways
        will clean and control it, head gasket may be in order
        thank for pointing for cracked thermostat rubber, will fix it.
          Stainless = Stains Less, not Stains Never.
          Salt can still find it's way under the cowling. Salt is in the air - the cowling is not air tight. Salt is very good at finding it's way to much more obscure places than under a cowling.
            Try coating them with Fluid Film -- like Corrosion X but better
              Plus 100 on ALL the posts above. SS can rust. You don't need a head gasket, at least from one slightly rusted bolt.
              As posted, your engine sucks SALTY AIR from outside as it runs, so yes, its very exposed.
              Keeping the engine clean with a protective spray will about eliminate that corrosion. This product was recommended from the Yamaha dealer and seems to work ok: http://www.lpslabs.com/product-details/561
              Here's my TEN year old F150, but it gets coated occasionally(brackish and mostly salt water use):
                Always enjoy your engine photos, Scott - it looks brand new!
                What is this connector?
                  My Yanmaha Tech gives the power head a light film of BOSHIELD eveery time he removes the cowling. Yamaha now sells their own brand of that kind of film and in fact its is BOSHEILD in Yamaha packaging -- and it's less expensive. My moter is 15 years old and because of that misting it looks like new
                  Here's Yamaha Part Number -- Yamaha ACC-SLCNS-PR-AY New Silicone Spray Lubricant; ACCSLCNSPRAY
                    Your statement "Yamaha bolts, they are all stainless steel, should not be any rust" is incorrect. They must be of some stainless steel alloy that contains some ferrous metal as well. Do the simple magnet test as in the image. I'm sure Yamaha uses an alloy rather than pure stainless because stainless is very brittle, and shear strength is limited. As long as you do not clean/treat your hardware, it will rust.
                    Chuck,
                      The windshield wiper fluid pump plugs in there...
                      I have no idea!!!
                        Not the stat housing, maybe the gasket between head and cover.
                        right below temp switch in pic, a line of corrosion or something
                          I have no idea!!!
                          It is the connection point when one is interfacing their motor with a laptop PC running YDIS software.
                            Looks like corrosion sneaking out from the water jacket cover to the head. (long line of white, double click to enlarge).
                            The head to the block has a little too.
                              Excellent, thanks!
                              I have a brand new program, just haven't installed in the lap top yet-
                              Yamaha YDS Pro kit $125.00.
                              Don't have a clue how to use it either, not yet at least..
