took the vst off my 2005 Yamaha 225 to clean it,while doing that I also removed the strainer. I was wondering how much resistance there should be from the strainer if I try to blow through it?
how much resistance
Spec is 2.45 psi when measured with lips in close contact with the strainer.
How in the world would someone be able to relay that kind of information as it's completely subjective? Some people blow harder than others, you know?
But, seriously, just look at it while holding it up to a light. You should be able to see through it. If there are any particles clogging the holes, you'll see them.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Originally posted by DennisG01 View PostSpec is 2.45 psi when measured with lips in close contact with the strainer.
ÂÂÂÂÂÂÂ
