can any one help me to find or cross reference so I can locate a carburetor rebuild kit. This engine I was told by Yamaha is made by GM . I would think that a match could be made with another application. Thanks for any help
yamaha 3.0 liter I.O.
I would remove the carburetor and take it to a good automotive parts store with some old folks behind the counter (Napa) or to a long time carburetor rebuild/repair shop. Or maybe the parts counter of a long time GM dealer. Hopefully someone there can identify the carburetor by part number or brand/model. From there you might be able to get to the part number for a rebuild kit.
Another thought is to buy a new carburetor and install/adapt it to your motor. This is done all of the time in the automotive world.
Yamaha stern drive stuff is well in the past now. Good luck.
Originally posted by JOHN SKELLENGER View Postcan any one help me to find or cross reference so I can locate a carburetor rebuild kit. This engine I was told by Yamaha is made by GM . I would think that a match could be made with another application. Thanks for any help
Yamaha Boat PartsScott
Originally posted by rodbolt17 View Postlook at the side of the fuel bowl on the stbd front corner.
you will see the Rochester numbers.
\Marine Carburetors|MerCruiser|OMC|Volvo Penta|All InboardsChuck,
If one goes to the Yamaha marine group home page and looks under the parts lookup function, there is a selection for stern drives. One can find part numbers for parts used on the L4, V6 and V8 models but good luck finding one of those parts. What is strange is that they may be stocked in Japan but Yamaha USA is no longer bringing them into the USA.
Would be nice if the OP stated precisely what model motor that he has.
We won't know unless the year, model, etc is posted.
If its a regular old Quadrajet 4 bbl(or 2 bbl), as I re-call, there was either a tag on the carb, or stamped in the body.
With that a kit can be found almost anywhere and a bunch cheaper than one with Yamaha stamped on the box...
Very simple carbs', jets in the bottom, accelerator fuel pump, darn near bullet proof...Scott
Probably a Rochester 2BBL..
Look at this link and see if it looks like yours.
1993 L4 3.0 Yamaha Stern Drive CARBURETOR 3 Diagram and Parts
Get the #'s on the body (Like a few of us have said), and order your kit. If you don't feel confident, have a reputable shop (Like the one I sent in a previous post) rebuild for you.Chuck,
no probably to it.
most folks have never seen a Yamaha sterndrive.
I have .
the Yamaha stern drive 3.0 used a basic simple 2bbl Rochester and carb kits are avalible from most any auto parts store.
I told you where the carb ID numbers are.
I have .
Â
