Water in oil
  • Water in oil
    Hello and Heeeeellllp !!!!!
    I have a Yamaha F40 2002 and has water in motor oil
    I spoke with one mechanic at Yamaha and he said it was one of the gasket under the engine head was leaking so to be safe I changed all gaskets that are under the motor head and thought and hoped that everything was in order but no, it is still water in oil
    I've screwed bolts with approximately right moment , the bolts should have a torque of 21Nm , key I spent went to 20Nm also tightened I bit extra .
    Is there anyone who has been involved in similar or knows where it can play water ???
