I recently acquired a boat with a 1993 200 TXRR motor. The motor runs great, but it looks like I will need to replace the multifunction gauges - they are barely readable. It looks like the current part # for the tach is 6Y5-83500-03-00, but according to boats.net the speedometer should be 6Y5-83500-A0-00, which is obsolete. Is there a newer replacement for the speedo? Will the original wiring harnesses work? Also, I have seen that Yamaha has a fuel management unit. Will it work with a 1993 motor? Any advice is much appreciated.
Replacement Gauges for a 1993 200
Originally posted by Elwood22 View PostI recently acquired a boat with a 1993 200 TXRR motor. The motor runs great, but it looks like I will need to replace the multifunction gauges - they are barely readable. It looks like the current part # for the tach is 6Y5-8350T-83-00 with adapter harness., but according to boats.net the speedometer should be 6Y5-83500-A0-00, which is obsolete. Is there a newer replacement for the speedo Yes 6Y5-83570-S6-00? Will the original wiring harnesses work? Yes. Also, I have seen that Yamaha has a fuel management unit. Will it work with a 1993 motor? Yes. Any advice is much appreciated.
http://www.boats.net/parts/detail/ya...50T-83-00.html
http://www.boats.net/parts/detail/ya...570-S6-00.html
See this document also. Page 3-2.
2016 Outboard Rigging & PartsLast edited by boscoe99; 08-14-2016, 09:24 PM.
Yamaha likely branded a product line from teleflex or similar. I replaced my fuel gauge with their trim gauge and found instruments differed only by the scale printed behind the needle. I doubt the same is true of the new computerized stuff. When shopping, I recall seeing packages offered as sets in styles to suit any decor.
Â
