1996 Salt Water Series
Model: S225TXRU
V-x Yamaha Engine
Engine Type: 76 Degree V-6
Displacement: 3130cc
Micro Computer Ignition
Naturally Aspirated; Carbureted
Please provide cylinder number/orientation and firing order.
Help with Problem Diagnosis and Solutions.
Problem followed by Tests Performed
Viewed from back of PowerHead, Top PortSide Cylinder Fails to produce Power.
Observations: Engine, at 2,800rpm is missing Considerably. On the water, WOT yields merely 4,200rpm; rpm decreases some & power weakens with time at WOT. See SparkPlug whaler1990 Album picture. Note the plug on the right. It is from the Top PortSide Cylinder and after one-hour running it appears new; no carbon discoloration. All plugs were replaced a forehand and at time of the picture, all had about one-hour runtime.
Therefore the focus of test is primarily the Top PortSide Cylinder.
All testing performed using Premium Ethanol free fuel in a new dedicated five gallon fuel tank.
Check Coil KV@2,800rpm
Procedure/Observation: Take KV readings from SparkPlug wire, just before spark plug.
Disposition: Problem cylinder is high on both of two separately installed coils. Viewed from back of PowerHead:
💥16KV 5KV
6KV 6KV
7KV 7KV
BoreScope Top PortSide Cylinder Wall
Procedure/Observation: Bore scope inside of cylinder and note observations.
Observation: Cylinder Walls appear normal through the BoreScope; walls are wet and machining cross-hatching remains visible.
Cylinder Top appears normal; carbon color with casting surface perceptible.
Secondary Compression
Procedure/Observation: Check secondary compression & note readings; viewed from back of Powerhead
Disposition:
Run test Cold
100psi 95psi
95psi 93psi
90psi 89psi-90psi
Check Valve
Procedure/Remedy: Apply 11.6psi/replace if BackFlow is noted.
Manual Pg 4-2
Disposition: Pressure holds at 11.6psi
Initial Fuel Flow
Procedure/Observation: Pull fuel line from Carburetor, remove SparkPlug Wires, Turn engine over & record fuel flow.
Disposition: Fuel discharged much Fuel. Squirts in HARD Pulses.
Check Fuel Pump Pressures
Procedure/Observation: Isolate each of the three Fuel Pumps; perform three individual checks. Disconnect outflow hose (the one coming from the fuel pump) from the carburetor. Connect a pressure gauge to fuel pump outflow port. Run engine & observe fuel pressure at each pump.
Dispositions:
Top Pump About 3.0psi
Middle Pump 4.0psi
Bottom Pump 4.0 to 5.0psi
FuelPump (1) Diaphragm
Procedure/Remedy: Apply vacuum to out port & block input port. Replace if vacuum LeaksDown
Manual Pg 4-2
Disposition: No remarkable LeakDown; tested dry.
🚫FuelPump (2) Test A
OutLet Valve
Procedure/Remedy: Apply 7.2psi positive pressure on outlet port; leave inlet open. Replace if BackFlow is noted.
Disposition: Unable to pressurize due to lack of pressuring device w/gauge. Will advise when completed.
Manual Pg 4-2
FuelPump (2) Test B
InLet Valve
Procedure/Remedy: Apply 4.3psi vacuum on inlet port; leave outlet open. Replace if BackFlow is noted.
Manual Pg 4-2
Disposition: Holds vacuum in dry condition with slight backflow, may be apparatus tubing leak.
Electric Fuel Pressure Pump Discharge & Pressure
Procedure/Remedy: Capture five seconds fuel discharge from Electric Fuel Pressure Pump. Min 41cc must discharge over a period of five seconds with Key-on. Check fuel pressure
Manual Pg 4-6
Disposition: 58CC in Beaker over 5 seconds at 4.0psi
🚫Fuel Pressure Regulator
Procedure/Remedy: Apply pressure to pressure regulator. Regulates Pressure at 1.4psi
Manual Pg 4-6
Disposition: Manual is unclear exactly how to test. Will advise when completed.
Enrichment Line Filter
Procedure/Remedy: Remove enrichment line & blow out filter from inside Fuel Control Port.
Manual Pg 4-9
Disposition: Bore scoped the enrichment port and the enrichment line filter tube; no debris or buildup observed. Lightly applied air from inside the enrichment valve hole being careful to not lose the O-Ring; some fuel and no apparent debris or dirt exited the filter tube.
Pilot Screw
Procedure/Remedy: Remove & Inspect. ReInstall until seats softly; turn out 1 1/8 Turn +-1/4. Replace if taper is worn.
Manual Pg 4-9
Disposition: No apparent wear on pilot screw taper is noted. Original machining is in tact and undisturbed.
Test Fuel Control Solenoid
Check Valve Closes/Seals
Procedure/Remedy: Apply 1.4psi pressure & it should hold for One-Minute. If Leak-down Replace.
Manual Pg 8-18
Disposition: Leak-down test acceptable; holds much longer than one minute.
Fuel Control Valve Opens
Procedure/Remedy: Apply 1.4psi pressure & it should hold thence release when 12volts are applied to solenoid
Defective-->Replace
Manual Pg 8-18
Disposition: Pressure release test good
Check Fuel Control Solenoid (Enrichment Valve) at Carb while Engine Running
Procedure/Observation: Disconnect Fuel Control Solenoid from wiring harness. Run rpm up until engine is missing; hold that rpm. Thence apply 12 volts to Fuel Control Solenoid.
Observation: Engine rpm drops but, engine smooths out; miss substantially subsides.
Test Firing by Pulling Plug Wire
Procedure/Observation: Note rpm difference with SparkPlug wire connected/disconnected.
Observation: No rpm difference noted with SparkPlug wire connected or disconnected. With other cylinders, idle rpm substantially lowers when SparkPlug wire is disconnected.
Test Firing by squirting fuel into Carburetor Venturi during high speed miss
Procedure/Observation: Inject fuel into carburetor Venturi during the high speed miss.
Observation: Shortly after injecting fuel into carburetor, the high speed miss desists momentarily thence begins again.
Model: S225TXRU
V-x Yamaha Engine
💥16KV 5KV
6KV 6KV
7KV 7KV
Disposition:
Run test Cold
100psi 95psi
95psi 93psi
90psi 89psi-90psi
Check Valve
Manual Pg 4-2
Initial Fuel Flow
Dispositions:
Middle Pump 4.0psi
Manual Pg 4-2
OutLet Valve
Manual Pg 4-2
FuelPump (2) Test B
InLet Valve
Manual Pg 4-2
Manual Pg 4-6
Manual Pg 4-6
Manual Pg 4-9
Pilot Screw
Manual Pg 4-9
Manual Pg 8-18
Defective-->Replace
Manual Pg 8-18
