Guys I had my boat out today and noticed that I could not get reverse. I Also noticed that when I return the gear selector back to the neutral position, the boat continues forward at idle. I actually have to pull reverse to get the engine into neutral. I must also make it noted that I couldn't get full throttle. Now me thinking logically, I'm thinking it could be a stretched throttle or selector cables? If I'm wrong I'm open to suggestions. its Pro V P200TLRP
Shift Issue
Originally posted by cpostis View PostSounds like you have to perform a "Timing and Synchronization" on your motor. You should get a service manual for your motor and carry out the procedures within. Well worth the investment.
Anything else I should be looking for
Originally posted by rodbolt17 View Postthe shift shafts were known to rust away.
then it twists instead of shifts.
there is a US company that makes a two part shaft that eliminates the need to remove the powerhead for replacement.
look at the fwd edge just along the top of the lower where the speedo tube and bonding wire goes into the midsection.
look at the shift shaft.
if it is hour glassed it has most likely failed.
occasionally they will fail at the top.
normally at the lower.
Originally posted by Sydney Skier View Postrightio then whats this going to achieve? I'm not sure Timing the engine will change the gear selecting. Ill grab a manual and have a look. thanks for the heads up ill have a read and see what I can come up with
Have you checked the shift shaft for wear/corrosion, as Rodbolt suggested?Chuck,
Would the US company that you are referring to be known as ShiftShaft - shiftshaft.com?
My shaft on my 1993 115hp is rusty so I might be replacing it in the near future.Last edited by AK115V4-93; 08-03-2016, 12:32 PM.
ÂÂÂ
