New 175 SHO vmax water PSI sensor?
  • New 175 SHO vmax water PSI sensor?
    I have a new SHO and command link gauges. I adding the water psi sensor so it will read on dash I did my 250 last yr but cant remeber if their is a wire with a weather cap that has to be connected together like for the trim to get it to send the data. I connected the trim pink wires together and it is reading now. The correct plug is on the sensor already.
    No additional wires need to be connected together. Simply install the optional pressure sensor, make the electrical connection, and water pressure should show up on the gauge.
    Now you may have to make a selection on the gauge itself so that water pressure is displayed.
