I recently came into possesion of an old yamaha 3.5 air cooled OB that I was hoping to use to tide me over till I can get something better. There have been a few issues to sort out including rust in the tank. The main problem now is that it will not run without the start/ choke out and only then for about 3 or so seconds then dies. It wont start at all without choke out. I have striped the carb 3 times the last time I soaked the jets overnight in carb cleaner. Its got fresh fuel.a new fuel filter. a new spark plug and I have checked that there is a spark there and the filler cap vent is clear. This fault came on suddenly. any help appreciated.
Old 3.5 air cooled
Sounds like the carb is plugged up...
Besides the jets, make sure ALL those tiny orifices are clear....
A fine, spritz of pre-mix into the intake when cranking should bring it to life, for a second or two....
That'd confirm the carb is the issueScott
ÂÂÂÂ
