I lifted my motor at the lake today and it was stuck in the up position. I figured out how to lower it manually (bleed screw on the side of the trim housing). I checked the fluid level , which was fine but the problem still persists. The motor raises and lowers good without hesitation , but if the ram tops out it will not lower even though the trim motor seems to be working fine.. Any suggestions for a fix would be greatly appreciated. Thx
Power Trim Problem F100TLRX
Had same issue and thought my fluid level was fine. I do have a small leak. I took a squeeze bottle and blasted fluid into that tank and then quickly put cap on. Ran it up and down, Did it once again and it works fine. I will have to address leak at some point or I will have to continue this from time to time.
