Got to see a Yam helm master in operation recently. Wondering about the various actuators necessary to accomplish this. Would they be hydraulic? Boat or engine mounted? I guess you would need one for throttle, shifter and steering? Fancy stuff no doubt....would you even need an Icv if you had an "auto throttle" so to speak?
Cables versus fly by wire
The engines are hydraulically steered via power steering. Some engines can turn left while others might turn right or stay straight ahead at the time. Some may be in reverse while others are in forward gear.
By ICV do you mean the idle control valve? The bigger engines don't use an idle air control valve. The throttle valve is electronically con*****ed to allow the necessary amount of air into the system.
Helm Master | Yamaha Outboards
I was looking at the Yam site. I couldn't see any real mechanical explanation. How is the shifter driven into and out of gear?
Granted, this technology is way above my pay grade at this time. There was a show where this was mounted on a 36ft Grady with triple 300s. 500 or 600K boat......retractable awning, grill, diesel genset Blah blah blah
Originally posted by pstephens46 View PostI was looking at the Yam site. I couldn't see any real mechanical explanation. How is the shifter driven into and out of gear?
Originally posted by pstephens46 View PostBoscoe, thanks. Should have been more clear. Wondering what Yam is using to move the actual shifter shaft? Motor, hydraulics, solenoid etc. versus the regular cable action.
Originally posted by pstephens46 View PostCool! Thanks. Assume SDS is standard, hell prob standard on all these motors these days. Hope one cannot hack this system. Be hell at the dock if so.....
To me it stands for Shift Dampener System. A type of hub used with some Yamaha propellers.
Not sure how it applies to the DEC. Digital Engine Control. Where the engines are throttled and shifted via servos.
Originally posted by pstephens46 View PostAssuming SDS is standard on the digital motors, probably easier on the servo for shifting purposes. I do not have SDS, you can hear me shift from 75 yards away. Big clunk! Never any metal in foot oil though!
The servo is not affected by the type of propeller hub. Now the gear case, that is a different subject.
You seem to be a thinker like fairdeal. Good for you.
Originally posted by pstephens46 View PostCan we spin a prop too fast. Cavitate to the point of uselessness. Maybe variable pitch prop?
Again, like cars, smaller engines with more gears to make up for cubic inches..Scott
Â
