ongoing idle issues..2008 F90txr
had intermittent poor idle, wouldn't start at all sometimes, if i cracked the throttle open in neutral it would run at about 1000rpm but if i backed down the throttle it would stall, replaced ISC worked perfect for about 10 hrs then started acting up again... no codes at all.
found the wires were broke and rewired. so now i have 3 ISC valves. with the YDS all three move on the static test. the older 2 i can not get the motor to run at all. the newest one it will run while its cold but will stall in 10 minutes.. and won't restart until it sits a while...i notice that when i run the static test when it returns to 60% the pintle on the three valves are at different lengths the shortest to the longest is about 1cm difference.
I have little faith in the place i bought the boat and took it to for help. they told me they knew the ISC was bad because the resistance across the poles but when i checked were the same as the brand new one i had put in
Can the bad wiring harness cause the newest ISC valve to start to fail???
I'm trying to figure out what is causing these to go bad as opposed to continue throwing 200 dollar bandaids on the problem..
here are some YDS #'s can y'all tell me if theres anything that stands out
i got it to run for 10 minutes or so before it stalls
Save date,July 08 2016,
ECM No.:,6D88591A11,
Diagnosis,
,Code,Item,Result,Condition,
,13,Pulser coil,Normal,,
,15,Water temp sensor,Normal,,
,17,Knock sensor,Normal,,
,18,Throttle position sensor,Normal,,
,19,Battery voltage,Normal,,
,23,Intake temp sensor,Normal,,
,28,Shift position switch,Normal,,
,29,Intake press sensor,Normal,,
,37,Intake air passage,Normal,,
,44,Engine stop lanyard switch,Off,,
,49,Over cooling,Normal,,
Diagnosis Record,
,Total hours of operation,151,
,Code,Item,Occurred,
,37,Intake air passage,140.8,
,23,Intake temp sensor,141.4,
,29,Intake press sensor,141.4,
Engine Monitor,
,Monitor Item,Result,Unit,
,Engine speed,726,r/min,
,Intake pressure,37.51,kPa,
,Intake pressure,11.02,inHg,
,Atmospheric pressure,1016.1,hPa,
,Atmospheric pressure,30.1,inHg,
,Ignition timing,TDC,deg,
,Battery voltage (12-16),13.50,V,
,TPS voltage (0.5-4.5),0.992,V,
,Throttle valve opening (0-90),7.4,deg,
,ISC valve opening,38,%,
,Fuel injection duration,2.60,ms,
,Water temperature (below 90),57.9,°C,
,Water temperature (below 194),136.1,°F,
,Intake temperature (below 70),46.5,°C,
,Intake temperature (below 158),115.7,°F,
,Engine stop lanyard switch,OFF,,
,Shift position switch,ON,,
,Oil press switch,ON,,
,Dual engine system switch,OFF,,
Data Logger[Engine operating hours according to engine speed],
,Engine speed,Time[h],
,- 1000 r/min,70.0,
,1000 - 2000 r/min,33.7,
,2000 - 3000 r/min,9.2,
,3000 - 4000 r/min,6.1,
,4000 - 5000 r/min,29.8,
,5000 - 6000 r/min,3.0,
,6000 - 7000 r/min,0.0,
,Engine hours,151,
Data Logger[Data comparison graph],
,Engine speed[r/min],Battery voltage (12-16)[V],TPS voltage
(0.5-4.5)[V],Water temperature (below 90)[°C],Intake pressure[kPa],Oil
press switch[0:OFF 1:ON]
,2100,14.58,1.80,64.2,89.3,0,
,2200,13.77,2.09,64.2,95.3,0,
,800,13.62,1.00,32.9,41.0,0,
,700,13.62,0.98,39.5,41.0,0,
,650,13.48,0.98,51.9,41.5,1,
,700,13.55,0.98,46.5,44.9,1,
,1500,14.06,1.15,62.5,45.4,0,
,550,12.67,0.98,48.7,47.4,1,
,800,13.40,0.98,44.0,42.0,1,
,1100,14.14,1.00,60.8,30.6,0,
,650,13.70,0.98,61.7,35.0,1,
,800,14.14,1.00,59.3,33.6,1,
,550,13.11,0.98,54.4,43.9,1,
Diagnosis,
Diagnosis Record,
Engine Monitor,
,Engine speed,679,r/min,
,Intake pressure,40.70,kPa,
,Intake pressure,11.89,inHg,
,Atmospheric pressure,1010.8,hPa,
,Atmospheric pressure,29.9,inHg,
,Ignition timing,BTDC 2,deg,
,Battery voltage (12-16),13.00,V,
,TPS voltage (0.5-4.5),0.987,V,
,Throttle valve opening (0-90),7.2,deg,
,ISC valve opening,58,%,
,Fuel injection duration,2.97,ms,
,Water temperature (below 90),48.0,°C,
,Water temperature (below 194),118.4,°F,
,Intake temperature (below 70),52.5,°C,
,Intake temperature (below 158),126.5,°F,
,- 1000 r/min,70.1,
,Engine hours,151,
,600,13.40,1.00,60.8,39.5,1,
,750,13.70,0.98,67.5,39.5,1,
,550,13.55,0.98,74.0,51.8,1,
Diagnosis,
Diagnosis Record,
Engine Monitor,
,- 1000 r/min,70.0,
,Engine hours,151,
Diagnosis,
Diagnosis Record,
Engine Monitor,
,- 1000 r/min,70.1,
,Engine hours,151,
