I have a 1997 Yamaha 175. Lately I've been getting a hot alarm when I run 35-40 mph. It will run all day at 30 mph with no alarm. Top end is 65 mph. My pressure gauge does funny while running. At idle speed it may show 3-4 psi or nothing. At higher speeds it may start with 20 psi then drop to 12 psi at the snap of your fingers. Pressure may drop just as fast to 8 psi. Pressure will continue to vary constantly 8-10 psi to 18-20 psi at the snap of your fingers. I did install a new water pump kit and new housing. This did nothing for my problem. I got this motor new and has never been in salt water. Any advice would be deeply appreciated. Thanks.
175 Yamaha with hot alarm.
Originally posted by Hunterhja View PostI have a 1997 Yamaha 175. Lately I've been getting a hot alarm when I run 35-40 mph. It will run all day at 30 mph with no alarm. Top end is 65 mph. My pressure gauge does funny while running. At idle speed it may show 3-4 psi or nothing. At higher speeds it may start with 20 psi then drop to 12 psi at the snap of your fingers. Pressure may drop just as fast to 8 psi. Pressure will continue to vary constantly 8-10 psi to 18-20 psi at the snap of your fingers. I did install a new water pump kit and new housing. This did nothing for my problem. I got this motor new and has never been in salt water. Any advice would be deeply appreciated. Thanks.
And do you flush the engine regulary, even though you never use it in salt water? Weed and mud could be slugging up your motor's cooling passages. Give that also a go, and flush whatever line you have to your gauge also if nowhere else to go.Last edited by zenoahphobic; 07-09-2016, 12:44 AM.
