I know the topic of dry corrosion has been visited ad-nauseam over the past few years. After successfully repairing a breach in the block of my TXRB (near the thermostat), I was informed that both engines now have dry corrosion. My question goes out to those that have had the repair done and if it extended the life of the engine sufficiently to warrant the cost of the repair. My engines (2003) have 1150 hours on them and perform like the day i purchased them (except they now overheat at low rpm). Thanks to all for your consideration and responses.
F225 Longevity post-dry corrosion repair
Originally posted by capnkingfish View PostMy question goes out to those that have had the repair done and if it extended the life of the engine sufficiently to warrant the cost of the repair. My engines (2003) have 1150 hours on them and perform like the day i purchased them (except they now overheat at low rpm). Thanks to all for your consideration and responses.
I did the work myself, and found it interesting and enjoyable. So, for only ~$700 for parts on an otherwise excellent engine (mine was a TXRD at 1,000 hrs) is was a "no brainer".
Originally posted by fairdeal View Posthmmm. Well, I would say the new exhaust parts themselves will likely last at least as long, or longer, than any other part of the engine. Yamaha seems to have "solved" that coating problem.
ÂÂÂÂ
