Motor ID?
  • Motor ID?
    I have an older, 1994ish Yamaha Two Stroke ProV 200.
    The data plate on the transom mount is worn off and was wondering if there was any other way to ID the engine.
    Is there another Data Plate on the engine somewhere other than the transom mount?
    Motor pics......
      Motor ID Pics
        examine the engine block, you may find a label like this
        free adult image hosting
        if you do, I believe Boscoe here can ID it for you
          I will look. Whereabouts did you find that label?
            It is normally on the block. In the vicinity of the starter motor.
              Couldn't find a sticker, but I did find a number stamped into the block = 004443
              If that means anything to you.
