Engine 97 Yamaha 200 SW 2 stroke carbed. 200 hours on factory new power head.
Last winter I pulled the plugs and I noticed #1 cylinder plug looked rather dry. I took engine into my local Yamaha dealer thinking maybe that cylinder was running lean. They tested spark, oiling and everything else that they would do on a service job. They didn't think the cylinder was running lean. They recommended I run and then inspect the plug and if I felt it was running lean to rebuild that carb.
Well I ran it on a fishing trip for a weekend and then inspected the plug and looked like it was still to dry.
I ended up putting a rebuild kit in the top carb. I did it myself and followed instructions per my manual.
Yesterday I put about 2 1/2 hours on the engine out fishing. Pulled the plug on that cylinder. To me it looks too dry compared to the other plugs
The plug on the right is from #1. The plug across from it is top plug on port side
This is a photo of #1 and the plug below it
So what y'all think. Do I have a problem or am I just paranoid ?
Btw I am running semi synthetic oil in the motor and engine has new water pump and thermostats
